4 years agoNot applicable
DO I need Visual studio and Power Query SDK to connect Power BI report to On-Premise SQL server???
I have published a report on PowerBI server, however it needs to connect to an on premise SQL server database. I read from documentation that I need to create a PowerQuery connector. DO I need to ha...
v-jingzhang
4 years agoHi Anonymous
Have you solved this problem? If so, kindly Accept an appropriate reply as Solution. If not, please provide more details about the problem. Thanks.
Community Support Team _ Jing
Hello @v-jingzhang
PREVIEW
Thank you for your answers on this. This has not worked for me yet. (the error messages from PowerBI are not very clear). Currently I am working with firewall team, powerbi admins and SQL admins in our Org to rule out any communication restrictions, and if there are restrictions then open up the communications between PowerBI VMs and SQL servers, and then try again. Once that is done, I will update the results here.
