Anonymous's avatar
9 years ago
Cortana integration with Power BI does not work
Hi team,
I have enabled "Allow Cortana to access this dataset" to each of the report that I published on PowerBI.com (am the data owner of the files) and have also included work account under settings as stated in this link below. However, I do not see my report using Cortana and also tried to reboot my machine, waited for more than 24 hours still no luck
https://powerbi.microsoft.com/en-us/documentation/powerbi-service-cortana-enable/
I also verified if I was using the right version of Windows 10 which is as listed, not sure what wrong am I doing here?
Edition: Windows 10 Enterprise
Version: 15.11
Thanks in advance.
Kind regards,
Anand
    Hi Anonymous,
    I test the scenario and I am not able to use Cortana feature with Power BI following the instruction in this article. However,  if I create a custom answer Page for Cortana following the steps in this article, everything works well.
    I got information internally that the capability of creating visuals using natural language within Cortana has been removed. We can create Cortana sized report pages and retrieve them through Cortana. In your scenario, please verify that if Cortana works as expected after you create custom answer Page for Cortana.
    Lydia Zhang
      AnonymousThanks for sharing the link below. However, I had already tried the same in my report by creating a page designed for cortana and keywords as required but still didn't help me. I also tried to create yet again today and it does not show up.
      Even in the page to test if cortana integration is working, i didn't see anything happening.
      Not sure what is wrong :(
      Kind regards,
      Anand
        Hi Anonymous,
        I test the Cortana on Win10 x64 version 1607, everythins works well. You can check the example in the following screenshot. Would you please share me your PBIX file which contains Cortana size page? Also how about restarting Cortana in your machine?
        Lydia Zhang
