Cortana integration with Power BI does not work
AnonymousThanks for sharing the link below. However, I had already tried the same in my report by creating a page designed for cortana and keywords as required but still didn't help me. I also tried to create yet again today and it does not show up.
Even in the page to test if cortana integration is working, i didn't see anything happening.
Not sure what is wrong :(
Kind regards,
Anand
Hi Anonymous,
I test the Cortana on Win10 x64 version 1607, everythins works well. You can check the example in the following screenshot. Would you please share me your PBIX file which contains Cortana size page? Also how about restarting Cortana in your machine?
Lydia Zhang
- Anonymous9 years agoNot applicable
Hi Anonymous,
Thank you once again for sharing the snapshots from your machine and also providing me ways to recheck the settings. I have tried to reset cortana and have tried to remove my office 365 account and connect it back but still there is no result as required.
Having said this, I will share you the file later today so that you can try at your end.
Kind regards,
Anand
Hi Anonymous,
As stated earlier, attached is a dummy file that I created today for sharing purposes. This is the dummy version of the file as I cannot share the actual file but i have used the same as the original file.
I hope you are able to download the file from the link below.
https://drive.google.com/file/d/0BwqXxSvYwRm8cXZzS2VXNngxOFk/view?usp=sharing
Kind regards,
Anand
Hi Anonymous,
Have you tried my PBIX file? With your PBIX file, I cannot get Cortana to work, however, if I change the page name to "Cortana new page", Cortana works well. I suspect the issue is caused by that you use reserved keyword "Cortana" as page name.
Lydia Zhang- Anonymous9 years agoNot applicable
Hi Anonymous,
I tried to rename the page name and tried but with no change in results i.e., I could have it working. In the earlier post of yours I could only access the screenshots but not the .pbix file to verify what am I doing incorrectly.
Kind regards,
Anand
