Find everything you need to get certified on Fabric—skills challenges, live sessions, exam prep, role guidance, and a 50 percent discount on exams.
Get startedEarn a 50% discount on the DP-600 certification exam by completing the Fabric 30 Days to Learn It challenge.
Hello together,
we had an automized currency conversion using the Query Builder from Eurostat (https://ec.europa.eu/eurostat/web/query-builder/getting-started/query-builder)
Normally we have used this code:
Quelle=Table.FromColumns({Lines.FromBinary(Web.Contents("https://ec.europa.eu/eurostat/wdds/rest/data/v2.1/unicode/de/ert_bil_eur_d?sinceTimePeriod=2019M07D0..."), null, null, 65001)}),
In Green you have the link to the Table ert_bil_eur_d
Unfortunately this link has changed today and does not work anymore.
The new link from the Power Query Builder from EuroStat is
If I want to use this link and include it into Power Query, it does not work for power BI.
Does somebody have made the same experiences or has some tips?
Thank you
It does work but it's rather a lot of data, 12535 records times 40 currencies.
Do you maybe want to limit the time range or the currency scope a bit? Use monthly rates?
Database - Eurostat (europa.eu)
