dltk
Advocate I
Advocate I
Connect Power BI to Movex ERP system
Hi everyone,
Just to check if anyone is able to connect Power BI desktop to a ERP system called Movex ERP.
Applications in Movex Enterprise Resource Planning :-
Resource & Material planning
Product data management
Project management
Financial controlling
Manufacturing
Maintenance
Financial management
Is there any way i can find out the connectivity to this ERP system ?
Danny Lim
Hi @dltk,
There is no built-in connector for Movex ERP System in Power BI. You would need to determine if the ERP system has OData feeds available or what is the database behind it, it is possible to connect straight to the OData feeds or the database from Power BI Desktop.
If none of the above methods helps, please submit an idea in the Power BI Ideas forum: https://ideas.powerbi.com/forums/265200 .
Lydia Zhang
Hi @dltk,
Lydia Zhang
Hi Lydia,
Thanks.
Danny Lim
