Configure connection string for datasource in Power Bi Reports from Azure Devops
I have a deployment pipeline in azure devops where I can configure the connection string in the appsettings of my webapp for my development and production environment . I have used powerBi embed to integrate Power Bi Reports in my webapp. Is there a way to set what is the datasource for my reports based on the value in my appsettings file which is set in my deployment pipeline.
If I have the connection string variable refer to my development database, then the reports should also use development database as their datasource.
1 Reply
- v-yanjiang-msft
Hi haddi ,
Please see if this document helps: Change data source connection strings with PowerShell - Power BI | Microsoft Docs
Community Support Team _ kalyjIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
