Anony_mous
Cleaning data in power query of power bi
I have a table with 3 columns and I am bit confused with cleaning the data the dirty data is as follows:
Order ID           category                      Amount
CA-2011-167199.    Binders|Art.          5.4 | 31
CA-2011-149020.    Tables|Binders.      17 |13
CA-2011-127614.    Fasteners|Art.         6 | 3.6
After cleaning the data the data should look like this:
Order ID.                Category.                Amount
CA-2011-167199.   Binders.                   5.4
CA-2011-167199.    Art.                          31
CA-2011-149020.     Tables.                     17
CA-2011-149020.       Binders                   13
CA-2011-127614.       Fasteners                 6
CA-2011-127614.        Art.                         3.6
All suggestions are helpful thank you in advance
tackytechtom
Hi @Anony_mous ,
How about this:
Before:
After:
Here the code in Power Query M that you can paste into the advanced editor (if you do not know, how to exactly do this, please check out this quick walkthrough)
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("Xcs7DoAgFETRrRhqJDwQySvRxBXYERs/iTYUqJ2Ld7QylidzJ0bRhtJoopJqT8xCimZL85L34ipCPmBXKw9YEoP85BVrozF3Z05PPG5pB41iwP1iS6wd1n6ZVszvB/TKQJVVyIcb", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Order ID" = _t, Category = _t, Amount = _t]),
    #"Split Column by Delimiter 1" = Table.SplitColumn(Source, "Category", Splitter.SplitTextByDelimiter(" | ", QuoteStyle.Csv), {"Category", "Category.2"}),
    #"Split Column by Delimiter 2" = Table.SplitColumn(#"Split Column by Delimiter 1", "Amount", Splitter.SplitTextByDelimiter(" | ", QuoteStyle.Csv), {"Amount", "Amount.2"}),
    #"Removed Other Columns 1" = Table.SelectColumns(#"Split Column by Delimiter 2",{"Order ID", "Category.2", "Amount.2"}),
    #"Renamed Columns" = Table.RenameColumns(#"Removed Other Columns 1",{{"Category.2", "Category"}, {"Amount.2", "Amount"}}),
    #"Removed Other Columns 2" = Table.SelectColumns(#"Split Column by Delimiter 2",{"Order ID", "Category", "Amount"}),
    #"Appended Query" = Table.Combine({#"Removed Other Columns 2", #"Renamed Columns"}),
    #"Changed Type" = Table.TransformColumnTypes(#"Appended Query",{{"Amount", type number}})
    #"Changed Type"
Let me know if this works for you 🙂
/Tom
https://www.tackytech.blog/
https://www.instagram.com/tackytechtom/
Did I answer your question➡️ Please, mark my post as a solution ✔️
Also happily accepting Kudos 🙂
Feel free to connect with me on LinkedIn! linkedIn
#proudtobeasuperuser
tackytechtom
Hi @Anony_mous ,
How about this:
Before:
After:
    #"Changed Type"
/Tom
