anywhereanytime's avatar
anywhereanytime
Helper III
11 years ago
Azure SQL DB + Adventure Works LT Sample DB + Power BI desktop + Power BI.com
OK, that was sure a mouthful + I could have added "Excel Power Query and Power Pivot" to Power XXX as well.
Anyway, our "end goal" is to FULLY utilize the long standing "Adventure Works dataset" - and - the "alternative" consumption to "Dashboards WITH Q&A"!
The "with Q&A" appears to be the "limiting path" as "we can CONNECT to the Azure SQL DB via PBI Desktop" ... BUT we ONLY GET "Sales" - versus - the Azure SQL "Direct Connect" to Power BI.com YIELDS more data tables ... but doe NOT allow Q&A ???
So ... has anyone "used the SQL Adventure Works SAMPLE" and had good success ???
No RepliesBe the first to reply
