Adapter gets old values in Power BI, but correct when running from Visual Studio - what's happening?
Hi Anonymous ,
Based on my experience, usually The server will turn on the security policy that prohibits crawlers. In this case, we need to add an identification flag to the headers of the request.
like this:
#"User-Agent"="Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36 Edg/106.0.1370.47"]
Stephen Tao
So apparently this did only fix the issue temporarily. I just got the same behavior once again, when trying to import some new data from the data source.
What's funny is, if I change the User-Agent to something new, for instance by changing a version number, it works again for a while, then goes back to the same issue after a while.
Pushing refresh on the data after including it in a report works: It gets a new token, then refreshes the data using that token. The problem usually occurs when going into the Get data dialog, and sometimes from the Transform Data window.
Is there something else I could try to get it more stable? Could this be a bug in Power BI / Power Query? Nonetheless it's some pretty strange behavior.
