A simple way for COUNTIF function in power query
Hello Community,
I have a data set as shown below. Is there a way to have this done in power query editor. Column A and B is the Data input and Column C and D are the results expected.
Every help in this regard is very much appreciated. Thanks in advance
JP
Second column with countif added.
let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlLSUTIGYkMwjtWBiMBEjcEipkCWKVTUCEXEBIzBugwMQCZYWqKYZQFiggmEXoQYVHcsAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [C1 = _t, C2 = _t, C1Desired = _t, C2Desired = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"C1", Int64.Type}, {"C2", Int64.Type}, {"C1Desired", Int64.Type}, {"C2Desired", Int64.Type}}), AddedIndex = Table.AddIndexColumn(#"Changed Type", "Index", 0, 1, Int64.Type), #"Added Custom" = Table.AddColumn(AddedIndex, "SUMIF_1_argument", each if [Index] = 0 then {AddedIndex{[Index]}[C1], AddedIndex{[Index]}[C2]} else {AddedIndex{[Index]-1}[C1], AddedIndex{[Index]-1}[C2], AddedIndex{[Index]}[C1], AddedIndex{[Index]}[C2]}), #"Added Custom1" = Table.AddColumn(#"Added Custom", "SUMIF_2_argumentC1", each #"Added Custom"{[Index]}[C1]), #"Added Custom2" = Table.AddColumn(#"Added Custom1", "ResultC1", (FirstIterator)=> List.Count( List.Select( FirstIterator[SUMIF_1_argument], each _ = FirstIterator[SUMIF_2_argumentC1]))), //second column #"Added Custom3" = Table.AddColumn(#"Added Custom2", "SUMIF_2_argumentC2", each #"Added Custom"{[Index]}[C2]), #"Added Custom4" = Table.AddColumn(#"Added Custom3", "ResultC2", (FirstIterator)=> List.Count( List.Select( FirstIterator[SUMIF_1_argument], each _ = FirstIterator[SUMIF_2_argumentC2]))) in #"Added Custom4"
- JW_van_HolstResolver IV
Nice challenge!
I have solved the first column. Number 2 is copy paste.let Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlLSUTIGYkMwjtWBiMBEjcEipkCWKVTUCEXEBIzBugwMQCZYWqKYZQFiggmEXoQYVHcsAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [C1 = _t, C2 = _t, C1D = _t, C2D = _t]), #"Changed Type" = Table.TransformColumnTypes(Source,{{"C1", Int64.Type}, {"C2", Int64.Type}, {"C1D", Int64.Type}, {"C2D", Int64.Type}}), AddedIndex = Table.AddIndexColumn(#"Changed Type", "Index", 0, 1, Int64.Type), #"Added Custom" = Table.AddColumn(AddedIndex, "SUMIF_1_argument", each if [Index] = 0 then {AddedIndex{[Index]}[C1], AddedIndex{[Index]}[C2]} else {AddedIndex{[Index]-1}[C1], AddedIndex{[Index]-1}[C2], AddedIndex{[Index]}[C1], AddedIndex{[Index]}[C2]}), #"Added Custom1" = Table.AddColumn(#"Added Custom", "SUMIF_2_argument", each #"Added Custom"{[Index]}[C1]), #"Added Custom2" = Table.AddColumn(#"Added Custom1", "ResultC1", (FirstIterator)=> List.Count( List.Select( FirstIterator[SUMIF_1_argument], each _ = FirstIterator[SUMIF_2_argument]))) in #"Added Custom2"- v-kelly-msftCommunity Support
Hi jpattamthanam ,
Great! How about column 2?Have you also achieved column 2?If so,could you pls mark the reply as answered to let more people find the solution?
KellyDid I answer your question? Mark my post as a solution!
- CNENFRNLCommunity Champion
Hi, jpattamthanam , in general, you may transform the target region (eg A1:B2 in your example) to list and use
List.Count(List.PositionOf( list , "substring" , Occurrence.All))to count the occurrence of a specific string.
- justinhAdvocate IV
Use "Group by" on column A, and choose "Count" as the metric, but click on "advanced" and add another metric, call this one "All" and select "All Rows" as the metric.
After the Group is complete, expand "All" to get your original rows back, but now with the Row Count column. Do the same for Column B and you are done.
- AnonymousNot applicable
But are the duplicates to be counted only those in the ranges of two rows and two columns? For example, the 3 in the second line comes from = COUNTIF ($ A2: $ B3; $ A3) the 1 of the sixth line comes from = COUNTIF ($ A5: $ B6, $ A6)
Ah! I get it.
You are right, my idea won't work.
I'm brainstorming what could work, but right now I've got nothing.
