jpattamthanam's avatar
jpattamthanam
5 years ago
A simple way for COUNTIF function in power query
Hello Community, I have a data set as shown below. Is there a way to have this done in power query editor. Column A and B is the Data input and Column C and D are the results expected.     ...
  • JW_van_Holst's avatar
    JW_van_Holst
    5 years ago
    Second column with countif added.
        Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45WMlLSUTIGYkMwjtWBiMBEjcEipkCWKVTUCEXEBIzBugwMQCZYWqKYZQFiggmEXoQYVHcsAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [C1 = _t, C2 = _t, C1Desired = _t, C2Desired = _t]),
        #"Changed Type" = Table.TransformColumnTypes(Source,{{"C1", Int64.Type}, {"C2", Int64.Type}, {"C1Desired", Int64.Type}, {"C2Desired", Int64.Type}}),
        AddedIndex = Table.AddIndexColumn(#"Changed Type", "Index", 0, 1, Int64.Type),
        #"Added Custom" = Table.AddColumn(AddedIndex, "SUMIF_1_argument",
            each if [Index] = 0
            then
                {AddedIndex{[Index]}[C1], AddedIndex{[Index]}[C2]}
            else
                {AddedIndex{[Index]-1}[C1], AddedIndex{[Index]-1}[C2],
                AddedIndex{[Index]}[C1], AddedIndex{[Index]}[C2]}),
        #"Added Custom1" = Table.AddColumn(#"Added Custom", "SUMIF_2_argumentC1", each #"Added Custom"{[Index]}[C1]),
        #"Added Custom2" = Table.AddColumn(#"Added Custom1", "ResultC1", (FirstIterator)=> List.Count( List.Select( FirstIterator[SUMIF_1_argument], each _ = FirstIterator[SUMIF_2_argumentC1]))),
        //second column
        #"Added Custom3" = Table.AddColumn(#"Added Custom2", "SUMIF_2_argumentC2", each #"Added Custom"{[Index]}[C2]),
        #"Added Custom4" = Table.AddColumn(#"Added Custom3", "ResultC2", (FirstIterator)=> List.Count( List.Select( FirstIterator[SUMIF_1_argument], each _ = FirstIterator[SUMIF_2_argumentC2])))
        #"Added Custom4"
