Martin_How
Issue when changing sharepoint list column headers / reading description fields from columns in SPO
Hi guys,
I looked everywhere but diddn't find an answer so here goes:
for our "measure" glossary we use a sharepoint list (SPOL) (so every user has quick acces to is).
We where planning on connecting each PBIreport to this SPOL so that we allso show this data on every first sheet of the report (as a reminder/catalog).
So far so good, we stored this connecting in a PBI template to use for every new report. But when we adjust the SPOL (add new column or change a column name) this connection fails.
Our question:
1) can SPOL handle "labels" for column headers so that we only change the label of the column header, but the PBI connection to the SPOL doesn't brake
2) in the SPOL there is a "description" field per column. How can PBI read this "description" field ? (because the normal SPOL connector doesn't show it (I only found some info regarding Power APPS to use this "description" field) .
0 REPLIES 0
May 2023 update
Power BI May 2023 Update
Find out more about the May 2023 update.
Submit your Data Story
Data Stories Gallery
Share your Data Story with the Community in the Data Stories Gallery.
