jasonyeung87
Helper IV
Helper IV
Deploy Power BI reports from on premise F&O problem
I have an on prem F&O environment and want to deploy Power BI reports. The following link provides me instructions on how to do this https://docs.microsoft.com/en-us/dynamics365/fin-ops-core/dev-itpro/analytics/configure-power-bi-int...
I've followed the steps in the link and also installed a data gateway on the server (as it's on prem). After setting this up, I tried to deploy a Power BI report (these reports are prebuilt), via the following:
I checked one of the reports and then clicked on "Deploy Power BI files" on the top left corner. It would process for a while and then fail with the following message:
While this is processing, I logged onto Power BI service, went to the "My workspace" workspace and noticed that the report I'm deploying is in the workspace, but will disappear when F&O fails. I opened the Power BI file and it has the error message at the top:
When I setup the data gateway in Power BI service, I was able to connect to the database. (user is "axdwadmin" and the database is "AXDW").
I was wondering if there is some additional info on how to allow F&O to deploy Power BI reports?
Jason
0 REPLIES 0
May 2023 update
Power BI May 2023 Update
Find out more about the May 2023 update.
Submit your Data Story
Data Stories Gallery
Share your Data Story with the Community in the Data Stories Gallery.
