taikuri
Power Automate flow against Power BI dataset returning incorrect amount of rows
Hey!
I have this query:
EVALUATE
FILTER(ExportTable,  ExportTable[Date] >= DATE(2022,7,7) && ExportTable[Date] <= DATE(2022,8,12) && CONTAINSSTRING(ExportTable[CustomerName], "CompanyName") == FALSE() )
When I run the query in Dax studio I get the correct amount of rows (42k) but when I run the same query in Power Automate, create a csv file from it and store it in SharePoint or through SFTP I get an incorrect number of rows (15k). If I run the flow month by month for the same time period I get a correct number of rows. Any ideas about what is causing the problem and what could be a solution? There are reasons why this has to be run in Power Automate and not just save the data from the DAX studio query so that is not a solution.
taikuri
Found a possible solution to this one. Seems like there is a row and value limit in DAX queries run in the power automate. To get further info check out this link. https://learn.microsoft.com/en-us/rest/api/power-bi/datasets/execute-queries#limitations
taikuri
May 2023 update
Power BI May 2023 Update
Find out more about the May 2023 update.
Submit your Data Story
Data Stories Gallery
Share your Data Story with the Community in the Data Stories Gallery.
