dmessias
Power Automate dont load options menu in PBI
Hey guys,
I'm having the following issue on the desktop version of PBI: I add a Power Automate visual to a PBI report, insert data, but when I click "edit" the system doesn't load the flow options. I'm on a blank screen.
Version: February/2023
When I open the same report in the PBI service, I can access the power automate editing menu normally. I have a feeling this is some memory/cache or version issue.
I've tried to include it in a new file, but the problem persists.
julianafa
The same is happening with me, since yesterday.
dmessias
Problem solved without intervention.
It was probably a systemic issue.
Thanks.
julianafa
PBI Sept Update Carousel
Power BI September 2023 Update
Take a look at the September 2023 Power BI update to learn more.
Learn Live
Learn Live: Event Series
Join Microsoft Reactor and learn from developers.
