Fabric is Generally Available. Browse Fabric Presentations. Work towards your Fabric certification with the Cloud Skills Challenge.
Location doesn't work inside Power BI Mobile
Hi, I have an app in Power Apps with a map object using the Bing connector. I embebbed it in a Power BI dashboard.
The problem comes when I access to the dashboard with Power BI Mobile (my OS is Android). Inside the app, I press a button that gets my current latitude and longitude through a variables, but the button doesn't update it. When I use it with Power BI service on my desktop PC, it works.
On the settings of my smartphone I allowed Power BI to get access to my location.
Someone had a similar problem and could solve it?
Thanks a lot!
do you know this documentation?
Filter a report by geographic location in the Power BI mobile apps
I do not yet understand your workflow between Power BI and Power App.
Could imagine, however, that the Power App Visual does not have the necessary rights in the Power BI Mobile App.
Did I answer your question?
Please mark my post as solution, this will also help others.
Please give Kudos for support.
Marcus Wegener work at KUMAVISION AG , one of the world's largest
implementation partners for Microsoft Dynamics. #
"Get the most out of data, with Power BI."
twitter - LinkedIn - YouTube - website - podcast
nickyvv
Hi @DevTaligent,
Did you get it working with only a Power BI dashboard, so without Power Apps?
Furthermore, an important limitation is that you can only filter by location in the mobile app if the geographic names in the report are in English.
Blog: nickyvv.com | @NickyvV
EStieg
Microsoft
Microsoft
Thank you for posting your question!  I've asked a few members of the community to review your post and respond if they have suggestions for you.  Do you have any additional info that may help them?
Thank you!
Eric
PBI November 2023 Update Carousel
Power BI Monthly Update - November 2023
Check out the November 2023 Power BI update to learn about new features.
Community News
Fabric Community News unified experience
Read the latest Fabric Community announcements, including updates on Power BI, Synapse, Data Factory and Data Activator.
Power BI Fabric Summit Carousel
The largest Power BI and Fabric virtual conference
130+ sessions, 130+ speakers, Product managers, MVPs, and experts. All about Power BI and Fabric. Attend online or watch the recordings.
