Calvinorr
Export PowerBI Data to Excel using Power Automate
Struggling to get this to work when trying to create a new file. It works fine if I have an Excel template already set up. However when I try to create a new spreadsheet based on a template (so with the same Table name etc) I get errors.
Using "Get File Contest using path" and then "Create File" - both these work and a new file is created in the right place.
But my "Add a row into a table" does not
I am having to custom code the Table name - as it does not know it. But using the correct table name.
 Getting this error
"status"400,
  "message""A value must be provided for item.\r\nclientRequestId: 17006e0c-ce6e-4d34-a6d5-02cc6346b6ca",
  "error": {
    "message""A value must be provided for item."
  "source""excelonline-ne.azconn-ne-003.p.azurewebsites.net"
I am stumped - based on Youtube video from @rezadorrani
Calvinorr
Thanks - will take a look at your video - but effectively it needs to be an Excel file - but I can review this and see if a csv file will meet the needs of the project.
christinepayton
Post Prodigy
Post Prodigy
Does it have to be XLSX specifically? It is much easier to create a CSV file, which might fit your need depending on what you're trying to do.
I have a video on creating CSVs that are sent to SharePoint with Power Automate here (this is not a Power BI-specific video but the technique is the same once you have your data in the flow): https://youtu.be/RBx-HbVpWTQ
Calvinorr
No, I never did - had to stick with a template
AlexH-IT
Hi Calvin, I was wondering if you're able to figure out or resolve the issue of adding a row into table in excel.
Thanks.
Alex H.
PBI Sept Update Carousel
Power BI September 2023 Update
Take a look at the September 2023 Power BI update to learn more.
Learn Live
Learn Live: Event Series
Join Microsoft Reactor and learn from developers.
Dashboard in a day with date
Exclusive opportunity for Women!
Join us for a free, hands-on Microsoft workshop led by women trainers for women where you will learn how to build a Dashboard in a Day!
MPPC 2023 PBI Carousel
Power Platform Conference-Power BI and Fabric Sessions
Join us Oct 1 - 6 in Las Vegas for the Microsoft Power Platform Conference.
