Building Power Virtual Agent responses from on-premise SQL Server Database of Legacy Application
If you are building a PVA for a legacy application which has crafted a web interface for Customers but the data you need to fetch resides in an On-Premise SQL Server being used by a WIndows Client, this approach comes in handy. I had to fetch job description from an on-premise SQL Server for my PVA hosted on a standalone marketing site web Page. SO below steps were followed in integration with a Power Automate Flow.
Create a new Flow with a SQL GetRow action or alternate step and configure the connection with your On-Premise SQL Server. Configure a query with Inputs from the PVA or a direct query to simply fetch the rows.
This is achieved by adding a Gateway for your on-prem database and using that on Power Automate Gateways.
Now once this is saved, call this flow from your PVA Authoring canvas and your PVA would be able to respond to user input
based on data fetched from on premise SQL Server.
Note: Please follow the steps bottom up in case implementing this starting from Gateway!
This is achieved by creating a flow and call as an action from your PVA.
AbhiSSRS
Solution Sage
Solution Sage
yes, this could be done, just refer on connection to Azure sql from PA.
daniyal
Hi, can this also be done for Azure SQL database?
AbhiSSRS
Solution Sage
Solution Sage
This is my post!!!
May 2023 update
Power BI May 2023 Update
Find out more about the May 2023 update.
Submit your Data Story
Data Stories Gallery
Share your Data Story with the Community in the Data Stories Gallery.
