I think many of you are familiar with the Power Platform, but let's go over it quickly.
The Microsoft Power Platform now consists of 4 products:
In a previous blog post on getting some interactivity in your presentation, I already talked about the integration of Microsoft Forms, Power Automate and Power BI, you can read about that here:
In this new 2-part series I would like to show an example of how Power Apps, Power Automate and Power BI can work better together!
Let's start with the final goal in mind. Let's say for example, I want to have an interactive quiz during a presentation or workshop. An attendee will answer a question and be awarded points for the (partially) correct answer. I want to have a form/an app where I can enter the name of the attendee and the score after having received an answer.
Ideally I also want to show the results on the same screen so I don't have to switch between entering a score and showing the result.
As you might have guessed, I will accomplish this by using 3 of the Power Platform products:
So the good thing is: there's no switching between screens, or refreshing a page involved.
The Power BI dashboard will look something like this:
With this goal in mind, let's have a look in detail at how we can achieve this!
The streaming dataset, of type push, has to be created before selecting the workspace in Power Automate, because otherwise the streaming dataset won't show up. In PowerBI.com you can create a dataset in any workspace, also in My Workspace. You do that by clicking on the +-sign in the home screen of your workspace.
Make sure you turn on the switch for Historic data analysis when creating the dataset. That way Power BI will store the data that's sent through this data stream, and you'll be able to do reporting and analysis on the collected data stream. This switch can also be used to clear the dataset.
The Date field is optional, but it could come in handy later, when I want to filter out my test values in the report for example.
Because we create a Power App with a button to save the data, and thus to manually trigger the flow, we need to create an instant flow over in Power Automate.
In Part 2 I will explain how to create the Power App, with a button to save the data to the streaming dataset. Last, I will also link the App to the Power BI Report and embed it in a Dashboard.
Join us for a free, hands-on Microsoft workshop led by women trainers for women where you will learn how to build a Dashboard in a Day!
