I have a Power BI report with a Power App embedded in it. I would like to use the Solutions functionality to move this from my DEV environment through TEST and PROD.
All of the components can be added to a Solution, but there is no dependency set up between the Power App and Power BI report. When I migrate the solution to TEST, the embedded Power App is the one from DEV. This cannot be easily repointed to the TEST Power App.
How can I ensure that the embedded Power App references the Power App that is in the same solution as the Power BI report?
Thanks.
Nikolas
One option is to utilize environment variables and direct them to the appropriate report in the target environment. The Power Platform ALM will handle the task of directing to the correct dashboard based on the deployment settings file. However, deployment of the Power BI report would require separate attention.
Alternatively, you can include the Power BI report in the Dynamics solution and migrate the entire solution. Unfortunately, there doesn't seem to be an easy way to link the report to the current environment. In this case, you would need to add a post-deployment step to update the datasource parameter of the Power BI report to match the current environment.
You can embed the Power BI Report in a Power App. Then create an environment variable to store the default value and current value of the report. Using this environment variable, you can set the respective workspace from which report is to be loaded. You can effortlessly deploy the Power BI Reports into respective workspaces for Dev, Test, Prod and deploy the Power Apps to Dev, Test, Prod. Then maintain one environment variable which holds the report value for that environment.
Hope this helps..
If I have answered your question, please mark your post as Solved.
If you like my response or got a direction forward to proceed, please give it a Thumbs Up. Appreciate your Kudos. You can accept more than one post as a solution.
Cheers,
PMDY
