evalindag
PowerApps for Power BI visual only uses small part of dataset
Hi
I'm not sure whether I should post this question here or at the Power Apps forum. You can maybe let me know if it should rather be there 🙂
I'm making an Power Bi report with an integrated Power App. So I choose the PowerApps for Power BI visual and select "Create New". My dataset includes 844 lines. However PowerApps only shows 5 lines from the data when the gallery has formed and I'm not sure how to get the rest of the data into the app.
At first I thought PowerApps were only showing this small part just for making the data and when I would transfer the data back to Power BI it would add the rest of the data, but that is not the case. So when I choose one of these 5 lines in the Power BI report they integrate with the app while if I choose one of the datalines which are not in the app the app shows no data.
Has anybody here had this issue and knows how to solve it? It would be greatly appreciated 🙂
Best regards
Eva
nickyvv
Hi @evalindag,
I wanted to let you know that by selecting the right labels (Power Apps and Power BI), your question is automatically sent to the correct forums for answering. And subsequent posts on this question are also synced through both forums.
Unfortunately, I haven't seen this happening, so I can't help you with your question, sorry.
Blog: nickyvv.com | @NickyvV
LearnSurvey
Fabric certifications survey
Certification feedback opportunity for the community.
PBI_APRIL_CAROUSEL1
Power BI Monthly Update - April 2024
April Fabric Community Update
Fabric Community Update - April 2024
Find out what's new and trending in the Fabric Community.
