TedPattison
Power BI Dev Camp: Learn Advanced Dataset Programming with Power BI April 29th at 2P PST
Next Thursday on April 29th I will be leading a Power BI Dev Camp sessions covering advanced dataset programming techniques. This session will examine both the Power BI REST API and the Tabular Object Model (TOM) and examine scenarios for using these two APIs together in a corrdinated fashion.
The session explains how to use the Power BI REST API to import PBIX files, update dataset parameters, set datasource credentials and start refresh operations. Campers will also learn how use TOM to create and clone datasets in the Power BI Service as well as how to write the code to extend the data model for a dataset by adding tables, columns, measures, hierarchies and table relationships. This session will also cover the essential dataset management topics including how to automate setting datasource credentials and running dataset refresh operations.
Session Prerequisite: Campers should be familiar with C# and developing with the .NET Framework.
Session Date: Thursday, April 29, 2021 at 2:00 PM EST / 11:00 AM PST
Session Linkhttps://aka.ms/PowerBIDevCamp04292021
More Info: Session description
