Open Side Menu
Skip to contentMicrosoft Fabric Community
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Issues
rcyber's avatar
rcyber
Icon for Resolver I rankResolver I
6 years ago
Status:
New
Using Edge instead of IE in Power BI Desktop
Hello there, As I understand Power BI desktop uses built-in IE browser that is actually very outdated. Is it possible to use Edge instead? There are a lot of issues with IE such as it does not sup...
Custom Visuals
Data Modeling
v-qiuyu-msft's avatar
v-qiuyu-msft
6 years ago
Hi rcyber,
Thank you for your feedback. I would suggest you post an idea here: https://ideas.powerbi.com/forums/265200-power-bi-ideas
Qiuyun Yu
Completed Ideas
  • Set as landing page feature missing in Apr 2026 update (Build 2.153.1206.0) both in Desktop and Serv
  • Input Slicer Bug: Cursor jumps to position 0 and values cannot be cleared in Service
  • Input Slicer Causing Browser Tab Freeze in Public Links (Started April 24, 2026)
  • Small multiples not fitting to scale
  • Previously working Mac calender visual now gives me a error every time I touch it!
  • Text Slicer does not reset via Bookmarks or Clear All in Power BI Service (Service-only behavior)
  • Text Input Slicer is not reset by bookmarks in Power BI Service while working correctly in Power BI
  • Azure maps not displaying mapped data points in publish to web when location used
  • Azure Maps reference layer transparency behaves differently after publishing to Power BI Service
  • Desktop Application Bug?? - PBI desktop application left navigation icons always solid black
  • © 2026 Microsoft
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
Share this pageShare on LinkedInShare on FacebookShare on XShare on RedditShare on BlueskySubscribe via RSSShare via email
