When renaming columns in the power query editor (Table.RenameColumns) the steps are applied correctly.
When clicking close and apply the table is refreshed and the old column names are there. Renaming doesn't get through.
Power Bi reports refreshed on the Power Bi service don't have this problem. This problem first appeared Friday the 16th.
We use the Dataverse connector to connect to dynamics.
Hi @JS-PBI ,
The issue has been reported internally, if there're any progress, I will update here.
Best regards,
Community Support Team_yanjiang
