Renaming columns in Power Query doesn't show up in Power Bi desktop model/data/report view
When renaming columns in the power query editor (Table.RenameColumns) the steps are applied correctly.
When clicking close and apply the table is refreshed and the old column names are there. Renaming doesn't get through.
Power Bi reports refreshed on the Power Bi service don't have this problem. This problem first appeared Friday the 16th.
We use the Dataverse connector to connect to dynamics.
Status: Accepted
Hi @JS-PBI ,
The issue has been reported internally, if there're any progress, I will update here.
Best regards,
Community Support Team_yanjiang
Comments
JS-PBI
Hi @v-yanjiang-msft ,
Thank you for the update.
Regards.
WillemM
Is there perhaps any progress for a fix of this very annoying issue ?
I would really appreciate that..... thx.
v-yanjiang-msft
Hi @WillemM ,
The fix is checked in. It will roll out in SU08.
Best regards,
JS-PBI
That's great news. That means it will be in the august release?
Regards.
JS-PBI
I have the August release (2.120.731.0) and I checked by refreshing a couple of tables:
All column names had the correct name, bug seems to be resolved.
felipe_souza
I also updated to August version (2.120.731.0) and I don't have the problem anymore. For me it's solved.
Felipe Souza
mayankdawar
I have installed version: 2.120.963.0 (August release) but still facing the same issue.
mayankdawar
@JS-PBI @v-yanjiang-msft Can someone please provide me with the link to download this version (2.120.731.0). As the issue still exists in the latest version.
JS-PBI
@Anonymous you can try the following link:
Downloads | Microsoft Power BI
But I recommend you get the version from the microsoft store (you will always have the latest version).
NBurnat
Advocate I
Hi @Anonymous
I am using Version: 2.123.742.0 64-bit (November 2023) and still experienceing the issue.
Step:  = Table.RenameColumns(#"Reordered Columns",{{"name", "Account"}, {"dict_list2suspectby", "List2suspectBy"}, {"dict_list2suspectdate", "List2suspectDate"}, {"dict_suspect2unqualby", "Suspect2identifiedBy"}, {"dict_suspect2unqualdate", "Suspect2identifiedDate"}, {"dict_unqual2passiveby", "Identified2passiveBy"}, {"dict_unqual2passivedate", "Identified2passiveDate"}, {"dict_passive2activeby", "Passive2activeBy"}, {"dict_passive2activedate", "Passive2activeDate"}})
not reflected in data model.
Cheers
Nicole
