Find everything you need to get certified on Fabric—skills challenges, live sessions, exam prep, role guidance, and more. Get started
Problem with Booleans in Power BI
When create a Boolean column in Power BI Desktop, the values are "True" or "False", but when push the document to Power BI service, de values are "0" or "1", causing that the filters used in Desktop version, returns no data in Power BI Service.
Status: Investigating
Hi @jrrodriguez
I created a simple sample, but it does not appear as you said, can you provide your sample for us to test ?
Comments
v-yetao1-msft
Status changed to: Investigating
Hi @jrrodriguez
jrrodriguez
I can only reproduce with my actual dataset (linked from sharepoint), I send you photos, but is imposible to send the entire pbix because of confidential data.
Power BI Destkop FilterPower BI Destkop FilterPower BI Service FilterPower BI Service FilterPower BI Desktop Calculated ColumnPower BI Desktop Calculated Column
DataSupportTeam
Hi guys!
Have you foung the solution for this issue?
I'm facing the same problem.
DataSupportTeam
I've just found that the solution is to set the column as type equals logical.
