Get Fabric Certified for FREE during Fabric Data Days. Don't miss your chance! Learn more
Problem connecting to SAS using OLEDb SAS.IOMprovider
ErrorErrorWe are trying to access data from a SAS grid using Integrated Windows authentication, single sign on. This works in Visual studio but in PowerBi we get the above error. The client doesn't want to supply credential every time they access a different folder or library. Any help will be appreciated
Status: Needs Info
Comments
v-haibl-msft
@dondokp
From the error message, it seems that the connection string is not correct. Do you include credential and security related properties in it?
Herbert
Vicky_Song
Impactful Individual
Status changed to: Needs Info
dondokp
Hi Herbert
Thanks for your response. The connection string is as follows
Provider=SAS.IOMProvider;Data Source=iom-name://SASApp - Logical Workspace Server;SAS Metadata Location=’iom://MYSERVER:8561;Bridge;SECURITYPACKAGE=Negotiate’
Since we are using Integrated Windows Authentication , is it necessary to put in credentials? In Visual studio we don't have to enter credentials.
Kudzayi
Any luck solving this?
Otacon
This is for a SAS IOM Provider through OLEDB:
First in conetction string put this conection string (your IOM-NAME could be different)
Provider=sas.IOMProvider.9.47; Data Source=iom-name://SASApp - Logical Workspace Server;SAS Port=8561;SAS Protocol=0;SAS Server Type=1;SAS Metadata User ID=xxxx;SAS Metadata Password=xxxx;SAS Metadata Location=[your metadata server];SAS Workspace Init Script="LIBNAME [your libname] '[route]'";
then click on accept
in the next window put the metadata server credentials "SAS Metadata User ID=xxxx;SAS Metadata Password=xxxx"
and click to conect. if everything is fine youll see the datasets in your library listed
