Microsoft is giving away 50,000 FREE Microsoft Certification exam vouchers. Get Fabric certified for FREE! Learn more
Power Bi embedded: round edges not visible anymore when using outline
I have multiple buttons etc in my report where I have round edges in the outline.
Now everything is fine in Desktop and Service but in Embedded the round edges are gone.
example:
desktop:
 RightRightRightRight
Embedded:
WrongWrongWrongWrong
Status: New
Comments
v-robertq-msft
I can hardly create the same button as yours in the Power BI desktop, would you like to share a sample pbix file with the same issue without sensitive data or share some screenshots of how to create the same button as yours?
Thank you very much!
Community Support Team _Robert Qin
Karola
Advocate I
I cannot upload a PBIX file here??
what i see now, (probably since the latest desktop version) is that the rounding of the corners is no longer under ''outline'' but under ''shape''. maybe there's a bug in that so it will not view the right way in embedded.
I see there is also another issue reported with the same problems.
issue : Button - alignment and rounding issues with Sept 21 release
https://community.powerbi.com/t5/Issues/Button-alignment-and-rounding-issues-with-Sept-21-release/id...
euzebyolyra
This is a critical visual bug , any update from Microsoft would be great!
Thanks in advance
shreyas4315
Hi I am facing the same issue. The corners on buttons are no longer rounded when the report is embedded. Although, they do appear to have rounded corners when viewing inside the powerbi service. I have attached screenshots for both.
When Embededd:
Inside the Service (Check the Page numbers):
v-robertq-msft
A similar issue has also been reported internally, so stay tuned.
ICM:261759646
euzebyolyra
Always tuned, still waiting..
