Open Side Menu
Skip to contentMicrosoft Fabric Community
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Issues
Karola's avatar
Karola
Icon for Advocate I rankAdvocate I
5 years ago
Status:
New
Power Bi embedded: round edges not visible anymore when using outline
I have multiple buttons etc in my report where I have round edges in the outline.  Now everything is fine in Desktop and Service but in Embedded the round edges are gone.    example: desktop:   ...
APIS and Embedding
Reports
euzebyolyra's avatar
euzebyolyra
5 years ago
This is a critical visual bug , any update from Microsoft would be great!
Thanks in advance
Completed Ideas
  • Set as landing page feature missing in Apr 2026 update (Build 2.153.1206.0) both in Desktop and Serv
  • Input Slicer Bug: Cursor jumps to position 0 and values cannot be cleared in Service
  • Input Slicer Causing Browser Tab Freeze in Public Links (Started April 24, 2026)
  • Small multiples not fitting to scale
  • Previously working Mac calender visual now gives me a error every time I touch it!
  • Text Slicer does not reset via Bookmarks or Clear All in Power BI Service (Service-only behavior)
  • Text Input Slicer is not reset by bookmarks in Power BI Service while working correctly in Power BI
  • Azure maps not displaying mapped data points in publish to web when location used
  • Azure Maps reference layer transparency behaves differently after publishing to Power BI Service
  • Desktop Application Bug?? - PBI desktop application left navigation icons always solid black
  • © 2026 Microsoft
  • Manage cookies
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
Share this pageShare on LinkedInShare on FacebookShare on XShare on RedditShare on BlueskySubscribe via RSSShare via email
