I am trying to use the default dashboard for showing the change in total open issues over time in my repo. Unfortunately, this number is being computed incorrectly. Power BI says 704, but GitHub tell...
v-qiuyu-msft
6 years agoCommunity Support
Hi gopalv,
You can download the sample Github pbix file here. Then open it in Power BI desktop, go to Query Editor, find the Issues query table, you can see its Power Query.
Qiuyun Yu
