Power BI Desktop not connecting to Power BI Datasets
Feedback Type:
Frown (Error)
Timestamp:
2020-06-26T15:49:00.1926030Z
Local Time:
2020-06-26T11:49:00.1926030-04:00
Session ID:
7426dfb4-ebc9-43c2-a646-edcb18858d65
Release:
June, 2020
Product Version:
2.82.5858.961 (20.06) (x64)
Error Message:
We couldn't connect to your model in the Power BI Service. The dataset may have been deleted, renamed, moved, or it is possible that you don't have permission to access it.
Error Message Detail:
Either a connection cannot be made to the wabi-west-us-redirect.analysis.windows.net server, or Analysis Services is not running on the computer specified.
Stack Trace:
Microsoft.PowerBI.ReportingServicesHost.CannotRetrieveModelException: An error occurred while loading the model. Verify that the connection information is correct and that you have permissions to access the data source. ---> Microsoft.PowerBI.DataExtension.Contracts.DataExtensionException: Failed to open the MSOLAP connection. ---> MsolapWrapper.MsolapWrapperException: Could not initialize connection
at MsolapWrapper.Utils.ThrowErrorIfHrFailed(Int32 hr, String message)
at MsolapWrapper.Connection.Open()
at Microsoft.PowerBI.DataExtension.Msolap.Connection.OpenImpl()
--- End of inner exception stack trace ---
at Microsoft.PowerBI.DataExtension.Contracts.Utilities.RunSynchronously(Action action)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
at Microsoft.PowerBI.ReportingServicesHost.PoolableConnectionWrapper.<OpenAsync>d__8.MoveNext()
at Microsoft.PowerBI.ReportingServicesHost.Utils.TaskExtensions.WaitAndUnwrapException(Task task)
at Microsoft.PowerBI.ReportingServicesHost.LocalReportProcessingHost.ExecuteSchemaCommand[T](ExploreHostDataSourceInfo dataSourceInfo, IDbConnectionPool connectionPool, IConnectionFactory connectionFactory, IConnectionUserImpersonator connectionUserImpersonator, QueryExecutionOptionsBase queryExecutionOptions, ITelemetryService telemetryService, Func`2 action, String failTelemetryMessage, ServiceErrorStatusCode statusCode, ExploreBaseEvent exploreEvent)
at Microsoft.PowerBI.ReportingServicesHost.LocalReportProcessingHost.<>c__DisplayClass9_0.<GetModelMetadata>b__1(ExploreBaseEvent timedEvent)
at Microsoft.PowerBI.ReportingServicesHost.ExploreTelemetryService.<>c__DisplayClass4_0`1.<RunInActivity>b__0(ExploreBaseEvent activity)
at Microsoft.PowerBI.ReportingServicesHost.ExploreTelemetryService.RunInActivity(String activityName, Action`1 action)
at Microsoft.PowerBI.ReportingServicesHost.ExploreTelemetryService.RunInActivity[T](String activityName, Func`2 action)
at Microsoft.PowerBI.ReportingServicesHost.LocalReportProcessingHost.GetModelMetadata(ExploreHostDataSourceInfo dataSourceInfo, IDbConnectionPool connectionPool, IConnectionFactory connectionFactory, String modelMetadataVersion, QueryExecutionOptionsBase queryExecutionOptions, IConnectionUserImpersonator connectionUserImpersonator, ITelemetryService telemetryService)
at Microsoft.PowerBI.ReportingServicesHost.ReportingSession.GetModel(String dataSourceName, String modelMetadataVersion)
at Microsoft.PowerBI.ReportingServicesHost.ReportingSession.GetModelAsStream(String dataSourceName, String modelMetadataVersion)
at Microsoft.PowerBI.ReportingServicesHost.ReportingSession.GetConceptualSchema(String modelMetadataVersion, ParseConceptualSchema parse, ModelDaxCapabilities& capabilities)
at Microsoft.PowerBI.ExploreHost.Utils.ExploreHostUtils.GetConceptualSchemaImpl(IPowerViewHandler powerViewHandler, String databaseID, String maxModelMetadataVersion, ModelDaxCapabilities& capabilities)
at Microsoft.PowerBI.ExploreHost.Utils.ExploreHostUtils.HandleModelRetrievalExceptions[T](Func`1 wrappedCall, String databaseID, ServiceErrorStatusCode statusCode, FeatureSwitches featureSwitches)
at Microsoft.PowerBI.ExploreHost.Utils.ExploreHostUtils.GetConceptualSchemaAndHandleExceptions(IPowerViewHandler powerViewHandler, String databaseID, String maxModelMetadataVersion, ModelDaxCapabilities& daxCapabilities)
at Microsoft.PowerBI.ExploreHost.Utils.ExploreHostUtils.<>c__DisplayClass26_0.<TryGetConceptualSchema>b__0()
at Microsoft.PowerBI.ExploreHost.Utils.ExploreHostUtils.TryGetStructureImpl[T](Int64 modelID, ServiceErrorExtractor extractor, Func`1 getStructure, Func`2 validateStructure, T& structure, ServiceError& serviceError)
Invocation Stack Trace:
at Microsoft.Mashup.Host.Document.ExceptionExtensions.GetCurrentInvocationStackTrace()
at Microsoft.Mashup.Client.UI.Shared.StackTraceInfo..ctor(String exceptionStackTrace, String invocationStackTrace, String exceptionMessage)
at Microsoft.PowerBI.Client.Windows.ErrorHostService.GetErrorDetails(ShowErrorDialogArgs args)
at Microsoft.PowerBI.Client.Windows.ErrorHostService.<>c__DisplayClass2_0.<<ShowErrorDialog>b__0>d.MoveNext()
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine](TStateMachine& stateMachine)
at Microsoft.PowerBI.Client.Windows.ErrorHostService.<>c__DisplayClass2_0.<ShowErrorDialog>b__0()
at Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.<>c__DisplayClass1_0`1.<SendAndMarshalExceptions>b__0()
at Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.<>c__DisplayClass0_1.<SendAndMarshalExceptions>b__0(Object null)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at Microsoft.Mashup.Client.UI.Shared.WebDialogs.WebDialog.<>n__0(IWindowHandle owner)
at Microsoft.Mashup.Client.UI.Shared.WindowManager.ShowModal[T](T dialog, Func`1 showModalFunction)
at Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.ReportException(IWindowHandle activeWindow, IUIHost uiHost, FeedbackPackageInfo feedbackPackageInfo, Exception e, Boolean useGDICapture)
at Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.<>c__DisplayClass14_0.<HandleException>b__0()
at Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.HandleException(Exception e)
at Microsoft.PowerBI.Client.Windows.Utilities.UIBlockingAwareExceptionHandler.HandleException(Exception e)
at Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
at Microsoft.PowerBI.Client.Program.<>c__DisplayClass1_0.<Main>b__1()
at Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<>c__DisplayClass3_0.<HandleExceptionsWithNestedTasks>b__0()
at Microsoft.PowerBI.Client.Program.Main(String[] args)
OS Version:
Microsoft Windows NT 6.1.7601 Service Pack 1 (x64 en-US)
CLR Version:
4.7 or later [Release Number = 528049]
Peak Virtual Memory:
4.14 GB
Private Memory:
438 MB
Peak Working Set:
563 MB
IE Version:
11.0.9600.19596
Status: New
Comments
rmodi
Noticed that the error message says "api.powerbi.com"..  shouldn't this be "app.powerbi.com"?
I have tried everything..  March, April verions..  32bit, 64bit
nothing seems to work. Power BI Desktop just won't connect to Power BI Datasets.
v-yuta-msft
@rmodi ,
I have made a test but couldn't reproduce your issue. The desktop version on my side is 2.82.5858.961 64-bit (June 2020).
If this issue persists, please click "Copy details" and submit the error details in a support ticket here for further analysis.
Jimmy Tao
bdarbonneau
We have users here who experienced the same error. Was related to the enforcement of TLS 1.2.
Solution was found here:
https://community.powerbi.com/t5/Service/Analyze-in-Excel-connection-problem-NEW-failed-to-connect-t...
