Get certified in Microsoft Fabric—for free! For a limited time, get a free DP-600 exam voucher to use by the end of 2024. Register now
Power BI Desktop February 2023 DPI Scaling Problem
Since updating to this month's new Power BI Desktop release, the UI appears to be using my secondary display's DPI scaling upon launching a pbix file. The UI is blurry and zoomed in until I resize the window. Additionally, I'm unable to see the full dialog window of Get Data. It's zoomed in and I can't resize to see the OK and Cancel buttons. The only fix for that I've seen is to move Power BI Desktop to my secondary display temporarily.
Status: Delivered
Hi @GarettWP
This issue has been fixed in latest version . Please update your PBI Desktop to latest one .
Comments
LostHighway72
That is great and works for me.  Many thanks for the fix.
v-yetao1-msft
Status changed to: Delivered
Hi @GarettWP
jeffersonlbr
Same problem here. I'm using the latest version of PBI Desktop.
I can't see the update display and others features like conditional formatting.
victorar
The fix for Text scaling is going out in the March release...
Meanwhile either reset System > Accessibility > Text size to 100% or disable the MultimonitorDPI scaling using environment variable as shown in the prev post
Muhammadgad99
disabled the MultimonitorDPI scaling using environment variable and still has the same glitch
What should i do ?
valenciajessica
Hi I am facing a similar issue of the conditional formatting, "ok" button not visible, anyone knows how to fix? Much thanks.
Drunken_Sailor
You think they would fix it by now?  I do not want or need to change my settings for just this one application.
