Open Side Menu
Skip to contentMicrosoft Fabric Community
Forums
Inspiration
Ideas
Communities
Blogs
Learning
Support
RegisterSign In
  1. Microsoft Fabric Community
  2. Power BI forums
  3. Issues
volfied's avatar
volfied
3 years ago
Status:
Done
Power BI Dataset Stuck Refreshing and Won't Load
EDIT: The problem has been resolved.   ------------------------------   Hi. My Power BI Dataset is stuck in a refresh. It wouldn't load into the Desktop app for a little while, then I kicked off ...
Report Server
volfied's avatar
volfied
3 years ago
It just eventually resolved itself. Wasn't anything I did.
Completed Ideas
  • Set as landing page feature missing in Apr 2026 update (Build 2.153.1206.0) both in Desktop and Serv
  • Input Slicer Bug: Cursor jumps to position 0 and values cannot be cleared in Service
  • Input Slicer Causing Browser Tab Freeze in Public Links (Started April 24, 2026)
  • Small multiples not fitting to scale
  • Previously working Mac calender visual now gives me a error every time I touch it!
  • Text Slicer does not reset via Bookmarks or Clear All in Power BI Service (Service-only behavior)
  • Text Input Slicer is not reset by bookmarks in Power BI Service while working correctly in Power BI
  • Azure maps not displaying mapped data points in publish to web when location used
  • Azure Maps reference layer transparency behaves differently after publishing to Power BI Service
  • Desktop Application Bug?? - PBI desktop application left navigation icons always solid black
  • © 2026 Microsoft
  • Privacy & cookies
  • Terms of use
  • Trademarks
Your Privacy Choices Consumer Health Privacy
Share this pageShare on LinkedInShare on FacebookShare on XShare on RedditShare on BlueskySubscribe via RSSShare via email
