I am trying to refresh my tables in PowerBI but it keeps showing me the same error for any table I try to refresh : though this project 'bc14' is not related to the project I am using.
All my tables are from '232a' as show in the query editor : and there are not mentions of the project 'bc14'
What I have tried :
- Clearing the cache -> this did not work
- Resetting my credentials -> this did not work
- Specifying a Billing Project like below to force connecting to '232a' which is the right project -> this did not work and threw another error
- Connecting to the table via another Billing Project -> this did not work and I have the same issue as right above
- Connecting to the same table in another project -> this did not work
I am kind of short now on where this might be coming from ... I see that the issue is not new and happens quite often but I couldn't find any solution so far.
Would it be possible to get some help from PowerBI support team please ?
Many thanks, looking forward !!
You can consider sharing more details about this issue:
