Register now!Vote for your favorite vizzies from the Power BI Dataviz World Championship submissions. Vote now!
Created a Power BI Dataflow with the connection to other existing Power BI data flow using "Dataflow" connector, worked in the editing, but failed in refreshing once saved it.
Switched the connector from "Dataflow" to "Power BI Dataflow (Legacy)" and worked.
Dataflow connector has the issue with connecting to other Power BI dataflow when refreshing data. The refresh error message was
"Error: Data Source Error : DataSource.Error: Microsoft SQL: A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections. (provider: Named Pipes Provider error: 40 - Could not open a connection to SQL Server) DataSourceKind = <ccon>PowerPlatformDataflows</ccon> DataSourcePath = <ccon>PowerPlatformDataflows</ccon> Message = <ccon>A network-related or instance-specific error occurred while establishing a connection to SQL Server. The server was not found or was not accessible. Verify that the instance name is correct and that SQL Server is configured to allow remote connections".
