RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in the query (e.g. MyDate = GETUTCDATE () ). Neither approach allows a user to create an optimal request that brings down just the data he/she wants to see. My understanding is that filtering in Power View requires the superset of data to be retrieved before the filter is applied. Nondeterministic functions do not provide the flexibility of parameters. This will be an important feature when dealing with datasets large enough to cause performance and/or stability issues.
35 Comments
- nishalitNew MemberIt is now possible to define Parameters in Power BI Desktop, annotating them with metadata (name, description, expected data type and allowed values), reference these parameters from your queries, data model and report elements (labels, etc.). We'll continue making incremental improvements on top of the existing Parameters feature - so if there are specific items that you would like us to do based on this feature, please cast your votes. : )
- jon49New MemberAllow me to share a variable between queries. For example, so the source table of an Azure table could be changed in all the queries at once instead of requiring each query to be updated.
- kazlikHelper IIGreat news about this feature, was just being asked if I could do this today
- paul_schaeferNew MemberHello Mr. Llopis, how can this be achieved right now and when will the "easy-version" be available?
- i_feldmannNew MemberCurrently I’m using parameter tables in Excel to give the user the possibility to enter filters without needint to edit the code. This is not the greatest user experience so I’d very much appreciate the possibility to include this in the Power BI experience.
- selgamalNew MemberHi, I have the same request, powerbi is a great tool and this will be a valuable feature
- mark40New MemberCould you use the filers attribute to achieve this? https://powerbi.microsoft.com/en-us/blog/power-bi-api-updates-roundup/ (see at the bottom)
- fbcideas_migusrNew MemberHi Miguel, This is also one of the important features that will set PowerBI apart. Any SLA for implementing this ?
- kristian_olsonNew MemberYes! This brings Power BI closer to being able to utilize stored procedures better in SQL! Cant wait to recreate all my SSRS reports with Power BI!
- massouline365New MemberGood news! Waiting for this..
Recent ideas
Data Pipelines - Run only selected activities
For debugging and testing pipeline activities during development, allow us to select one or multiple activities and run only the selected pipeline activities. For example, I'm working on editing ...frithjof_v17 hours agoCommunity ChampionNew618Views11likes2CommentsSemantic model connection bindings should be in source control (Git)
Semantic model data source connection bindings should be source controlled. A semantic model can contain multiple data source references, each of which can be mapped to a separate Fabric data connec...frithjof_v1 day agoCommunity ChampionNew20Views1like0CommentsBulk changing column names in Visualizations Pane
We often use raw/api column names or measures with a set nomenclature to be consistent and to keep track of them but we do not want to display these names in the visuals. Currently we have to change ...vishal1401971 day agoFrequent VisitorNew6Views0likes0Comments
