RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
nishalit
10 years agoNew Member
It is now possible to define Parameters in Power BI Desktop, annotating them with metadata (name, description, expected data type and allowed values), reference these parameters from your queries, data model and report elements (labels, etc.). We'll continue making incremental improvements on top of the existing Parameters feature - so if there are specific items that you would like us to do based on this feature, please cast your votes. : )
Recent ideas
Request to add a feature to extract gateway connection status and last time credentials used
Could you please add a feature in the admin UI on Microsoft Fabric/Power BI to extract the Gateway connections with details of the gateway connection status and last activity information along with t...Vinodkumar_Chak1 hour agoNew MemberNew20Views1like0CommentsPower BI - incorrect handling of empty string parameter in DAX query in paginated report
Blank string parameters in paginated reports are treated as empty strings in Power BI Report Builder but as null values in the Power BI Service, resulting in incorrect report output. -> Create a pag...roshinikumarkar4 hours agoMicrosoft EmployeeNew24Views5likes0CommentsAllow NotebookUtils getSecret() to authenticate with Workspace Identity
Current behavior In Microsoft Fabric, notebookutils.credentials.getSecret() authenticates against Azure Key Vault using the identity of the user who executes the notebook. This behavior appli...tmihara6 hours agoNew MemberNew20Views1like1Comment
