RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
michael_colber1
6 years agoNew Member
Agree, need this input to refresh.
Recent ideas
Allow Managed Private Endpoint to be disabled/enabled per notebook
Could notebooks have an option to use or not use the workspace's Managed Private Endpoint (MPE)? MPE can significantly increase notebook startup time, even for notebooks that don't need private conn...frithjof_v43 minutes agoCommunity ChampionNew11Views1like0CommentsJustification Prompts When Downgrading or Removing Sensitivity Labels in Power BI Desktop
Description Currently, organizations can configure Microsoft Purview sensitivity label policies to require users to provide a justification when removing a label or lowering its classification. T...vvargasv16 hours agoMicrosoft EmployeeNew11Views0likes0CommentsVisual Type Defaults in Visualization Pane
This would change my life with fussy clients and client/public facing apps. In addition, it would allow me to add more value to the clients on retainers who do not have the 'hours' to allocate to...IolaWhiteley18 hours agoAdvocate IINew53Views7likes0CommentsMatrix: column totals as a bar chart docked to the edge
What's missing Data bars already work on the Total row and column through conditional formatting, so row totals can be read as length. Column totals cannot: they render as a horizontal bar inside a ...Sayurivalente18 hours agoRegular VisitorNew79Views6likes1CommentAllow Bookmarks to Affect Multiple Report Pages
Description: I would like to request the ability for a single Power BI bookmark to affect and maintain a state across multiple report pages, rather than being limited to a single page. For example,...Josegonzalez2118 hours agoNew MemberNew20Views4likes1Comment
