RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
michael_colber1
6 years agoNew Member
Agree, need this input to refresh.
Recent ideas
Semantic model connection bindings should be in source control (Git)
Semantic model data source connection bindings should be source controlled. A semantic model can contain multiple data source references, each of which can be mapped to a separate Fabric data connec...frithjof_v3 hours agoCommunity ChampionNew10Views1like0CommentsBulk changing column names in Visualizations Pane
We often use raw/api column names or measures with a set nomenclature to be consistent and to keep track of them but we do not want to display these names in the visuals. Currently we have to change ...vishal1401976 hours agoFrequent VisitorNew5Views0likes0CommentsAbout "Download SQL database project" and fix the downloaded project
1. The sqlproj must be fixed, it is downloaded without the xml markup line <?xml version="1.0" encoding="utf-8"> 2. The sdk must be updated: Actual: <Sdk Name="Microsoft.Build.Sql" Version="0.1...Jarrinf16 hours agoFrequent VisitorNew48Views3likes2Comments
