RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
i_feldmann
6 years agoNew Member
Currently I’m using parameter tables in Excel to give the user the possibility to enter filters without needint to edit the code. This is not the greatest user experience so I’d very much appreciate the possibility to include this in the Power BI experience.
Recent ideas
Variable Library: Disable default value set.
The Default Value Set in the Variable Library poses a risk. The Default Value Set will silently apply values when no explicit value set has been selected for a Test or Prod workspace. There i...frithjof_v5 hours agoCommunity ChampionNew634Views17likes2CommentsScheduled Refresh for Fabric Mirroring
Current Challenge: Fabric Mirroring runs continuously, leading to unnecessary data replication and higher Snowflake costs. There is no built-in option to schedule mirroring based on specific times o...ram_eternal1897 hours agoRegular VisitorNeeds Votes472Views3likes2CommentsMake workspace and item session persistence optional
Description The new persistent session behavior in Microsoft Fabric should be optional rather than forced. Currently, Fabric remembers the workspaces and items that were open in my previous session...TeemuMultanen8 hours agoAdvocate INew265Views42likes1CommentWhy are Calculation Groups so hard to modify?
Is there a way to make it easier to modify the DAX in a calculation group? I'm not sure if it's just me that finds this so annoying, but perhaps it's because I just started using calculation groups. ...AaronReasoner9 hours agoNew MemberNew8Views0likes0CommentsFeature Request: Add a Warning Prompt Before Deleting Tables That Contain Measures
Problem Statement: In Power BI, measures are linked to specific tables. When a developer deletes a table from the model view or report view, Power BI automatically deletes all measures assigned to ...Murtaza_Ghafoor12 hours agoSuper UserNew17Views2likes0Comments
