RAMUK1
11 years agoNew Member
Status:
Completed
Allow runtime parameters in Power View and/or Power Query
PowerView does not take input parameters at run time. In order to change the data being presented at runtime the user must use a filter or the query author must use a non-deterministic function in t...
jon49
6 years agoNew Member
Allow me to share a variable between queries. For example, so the source table of an Azure table could be changed in all the queries at once instead of requiring each query to be updated.
Recent ideas
Add "Collapse all / Expand all" to the Queries pane in Power Query Editor
Hi Fabric Community, I suggest adding a "..." menu beside Queries(n])with Collapse all and Expand all. Current state: With many queries, every group and Helper Queries folder is expanded. My 8...DataVitalizer9 minutes agoSuper UserNew1View0likes0CommentsAdd Automated Pre-Upgrade Compatibility Assessment for Fabric Spark Runtimes
Microsoft Fabric should provide an automated compatibility assessment before a workspace, Environment, notebook, or Spark Job Definition is upgraded to a newer Fabric Runtime. Spark runtime upgra...mourakshit1 hour agoNew MemberNew3Views0likes0CommentsSupport Creator-Independent Managed Identity and Ownership Transfer for Fabric Operations Agents
Microsoft Fabric Operations Agents should support an enterprise identity and ownership model that is independent of the individual user who originally created the agent. Today, an Operations Agent r...mourakshit1 hour agoNew MemberNew2Views0likes0CommentsAdd Centralized Health, Freshness Monitoring, and Alerts for OneLake Shortcuts
Microsoft Fabric should provide a centralized health-monitoring experience for OneLake Shortcuts across workspaces and data sources. As organizations adopt OneLake Shortcuts at enterprise scale, hun...mourakshit1 hour agoNew MemberNew3Views0likes0CommentsAdd Schema Compatibility Policies and Breaking-Change Detection to Fabric Event Schema Registry
Fabric Event Schema Registry should support configurable schema compatibility policies so teams can safely evolve event contracts without breaking downstream Eventstreams, Eventhouse ingestion, appli...mourakshit1 hour agoNew MemberNew2Views0likes0Comments
