Power BI Embedded: Problem using more than one filter on the same Embedded exporting all the Visuals
- 5 years ago
Hi, we solved it it was the [] characters when sending the filter.
I attach the solution!! Thanks!
function ReplaceFilters() {
//var a = $("#In1").val();
//var b = $("#In2").val();
const filterList = [{
$schema: "http://powerbi.com/product/schema#basic",
target: {
table: "tCalendarioNestleN",
column: "SemanaNestle"
logicalOperator: "And",
conditions: [{
operator: "GreaterThanOrEqual",
value: 1
operator: "LessThanOrEqual",
value: 5
target: {
table: "tProductos",
column: "cveCategoria"
operator: "In",
values: ["PURINA"]
}];var embedContainerPortafolio = $('#TendenciaSOut')[0];
var reportPortafolio = powerbi.get(embedContainerPortafolio); // Replace all report's filters.try {
reportPortafolio.setFilters( filterList);
// reportPortafolio.setFilters([filterList]); this was the one you sent us.
} catch (errors) {
console.log(errors);
/* catch (errors) { console.log(errors); }*/
target: {
conditions: [{
value: 1
value: 5
target: {
operator: "In",
values: ["PURINA"]
try {
} catch (errors) {
