rupakgautam
Issue with Microsoft Call Quality (Beta) Not Appearing in Power BI Desktop
Hi all,
I followed the steps to download and set up the Power BI query templates for Microsoft CQD but ran into an issue. Here’s what I did:
  1. Downloaded the Power BI query templates for Microsoft CQD from GitHub.
  2. Created a folder under the Documents directory called "Power BI Desktop."
  3. Created another folder called "Custom Connectors" within the Power BI Desktop folder (Documents\Power BI Desktop\Custom Connectors).
  4. Extracted the CQD-Power-BI-query-templates.zip and copied the MicrosoftCallQuality.pqx file into the Custom Connectors folder.
  5. Opened Power BI Desktop and went to File > Options and settings > Options > Security.
  6. Under Data Extensions, I selected (Not Recommended) Allow any extension to load without validation or warning.
  7. After restarting Power BI Desktop, I clicked on “Get Data” and then selected “More.”
However, the Microsoft Call Quality (Beta) option didn’t appear under Online Services. I tried the same process on another computer, and the option was visible there.
Has anyone encountered this issue or knows how to resolve it? Any help would be greatly appreciated!
Pepe1234
I had the same problem; all the procedures I saw on the forums didn't work. I found that pausing my firewall (Avast) worked.
rupakgautam
@Anonymous  I already  tired this and it did not work
Hi @rupakgautam ,
Here I have a test.
I download the connetcor and copy the .pqx into the Documents\Power BI Desktop\Custom Connectors
Aslo I select  (Not Recommended) Allow any extension to load without validation or warning. and restart the Desktop.
It works.
Please refer to below offical blogs to learn more details:
Install Power BI Connector to use CQD query templates - Microsoft Teams | Microsoft Learn
Connector extensibility in Power BI - Power BI | Microsoft Learn
Please download the latest Power BI Desktop version and try again.
Rico Zhou
