Error Exporting Power BI using Power Automate using RLS
That's not what I meant. Run the flow with high level permissions but inject the target user email into the RLS table via the report level filter.
Hi Ibendlin
Apologise but I don't understand when you say "inject in RLS table via report level filter".
Here RLS table sits in AAS.
Please correct me.
Ritesh
Hi Anonymous
I find some offical blogs about export Power BI Report by Power Auto.
For reference: Row-level security in Power Automate
Video: Send Report Email By RLS in Power BI using Power Automate
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Thanks Rico for your link.
I have already these options, and it works fine when "identities UserName" and "user running Power Automate" are the same but it fails when I want to run Power Automate for some other user, who has RLS setup and the source is AAS.
I think solution could be using Service Principal along with CUSTOMDATA, I will try this only the proper tenant-level access is granted to Service Principal.
However, I was looking for some example who has implemented this logic.
Ritesh
- lbendlin4 years agoSuper User
The links provided by Anonymous are interesting but a little misleading. It doesn't send emails as per RLS, but as per Role. The user identity is the one who renders all the reports, but as that role. It's nice if you have roles defined and want to send the same email to all users within a role, but it will not work with personalized individual emails as in your case. In your case you need to leave the role settings alone and manipulate the "Identities Username" dynamically. I think.
