Embeed Power Bi with Power BI Pro account
- Anonymous2 years ago
Hi Fabricio8798498 ,
For reference: Power BI Embedded: API to track your free embed token | Azure updates | Microsoft Azure
Rico ZhouIf this post helps, then please consider Accept it as the solution to help the other members find it more quickly.
Yes, this blog is about embed for customer. When you choose this method to embed, the customer doesn't need to sign in, even they don't need a Power BI account to view the embeded report.
The customer will use the embed token you generated for them to view the report.
For reference:Permission tokens needed to embed a Power BI app - Power BI | Microsoft Learn
Embed tokens with Pro or Premium Per User (PPU) license are intended for development testing, so a Power BI master account or service principal can only generate a limited number of tokens. Purchase a capacity for embedding in a production environment. There's no limit to how many embed tokens you can generate when you purchase a capacity. In development testing, you can use free embed trial tokens with a Pro license. To embed in a production environment, you must purchase a capacity.
For reference:
Frequently asked questions about Power BI embedded analytics - Power BI | Microsoft Learn
Rico Zhou
Anonymous where i can find the number of embed token avaliable in my azuere account ??
