Dax Help - Incorrect difference in time between 2 values of same datetime column
- Anonymous1 year ago
Hi RRaj_293 ,
1. Create measure.
Group_Second = var _new=MAXX(FILTER(ALL('Table'),'Table'[ID]=MAX('Table'[ID])&&'Table'[Process_Status]="NEW EMAIL"),[CREATE_DATETIME]) var _Com= MAXX(FILTER(ALL('Table'),'Table'[ID]=MAX('Table'[ID])&&'Table'[Process_Status]="COMPLETE"),[CREATE_DATETIME]) RETURN DATEDIFF( _new,_Com,SECOND)CustomerIDtime = FORMAT(TIME(0, 0, [Group_Second]), "HH:mm:ss")EachCustomerIDtime = var _table= SUMMARIZE(ALLSELECTED('Table'),[Customer],[ID],"Group_S",[Group_Second]) var _avg= AVERAGEX( _table,[Group_S]) return FORMAT(TIME(0, 0, _avg), "HH:mm:ss")2. Result:
Liu Yang
Thanks Anonymous I did something very similar and its now resolved.
However , Moving on with that solution I need to find the average processing time for each customer (total processing time/distinct count GUID) and display the final average time in Hours:Min:Sec.
Here's is whats is done so far -
Fore each customer's GUID which goes through a process sequence from 10(Process status = New Email) and 100 (Process status = Complete) , I have managed to find the time difference in Min:Sec format and the ones which dont complete the cycle (i.e process status <> Complete as last step) its marked as "Incomplete process". Its calculation DAX is as below -
I should now find the average time for each customer ignoring the "Incomplete process" ones. So I converted the time in Seconds and "Incomplete process" is made 0 for ease of calculation in the measure "Test_Totlprocessing TimeinSec" .
Please help! How do I find the correct average and display it in HH:MM:SS format?
| CustomerName | GUID | Test_ProcessTime | Test_Totlprocessing TimeinSec |
| ABC | 00272fd1 | 4 Min 58 Sec | 298 |
| ABC | 02a8b18b | 17 Min 59 Sec | 1079 |
| ABC | 035b8aa0 | Incomplete Process | 0 |
| ABC | 075ddfa8 | Incomplete Process | 0 |
| ABC | 0bba233d | 2 Min 33 Sec | 153 |
| XYZ | 1307af71 | 3 Min 24 Sec | 204 |
| XYZ | 148fd7bd | 2 Min 8 Sec | 128 |
| XYZ | 1655b305 | 5 Min 18 Sec | 318 |
| XYZ | 1be32838 | 54 Min 13 Sec | 3253 |
| XYZ | 1c3ab04e | 5 Min 11 Sec | 311 |
Your sample data is not covering your scenario. None of the averages exceed 60 minutes.
