Hello Community!
In this test case, my data is defined by two parameters: FF (D, De, N) and PB (A, B, C, D). FF is the main parameter. PB is a subordinate parameter. I am displaying the Values (Units), all data is made up, in a Matrix in Power BI. The Matrix displays the data as follows from top to bottom: D/A,B,C,D... De/A,B,C,D... N/A,B,C,D... and then it sums the data in the last line of the matrix.
My Question: Is there a way to sum D and De... as well as D+De+N... in the same matrix?
Test case PBIX file can be viewed/edited
https://www.dropbox.com/s/6zyr0qbcen1uume/190612Dev.pbix?dl=0
Thanks in advance for assistance!
Bery best,
mibu
@mibu ,
In the visual level filter pane, select "D" and "De".
Community Support Team _ Jimmy Tao
@mibu is this what you are looking for?
Learn Power BI and Fabric - subscribe to our YT channel - Click here: @PowerBIHowTo
If my solution proved useful, I'd be delighted to receive Kudos. When you put effort into asking a question, it's equally thoughtful to acknowledge and give Kudos to the individual who helped you solve the problem. It's a small gesture that shows appreciation and encouragement! ❤
Hi @parry2k, yes that is it. Thank you!! Your solution uses a second column... is there a way to get the summation of D and De to fall under the summation of De... and then carry on in same matrix summing N... and then summing all three FF (i.e., so we don't have to create an extra column)? Thanks! mibu
@mibu can you clarify what you mean by D and De and I'm taking 2nd column? What you are expecting the output to be?
103 | |
88 | |
78 | |
71 | |
69 |
113 | |
99 | |
97 | |
72 | |
68 |
