I have two similar flows triggered when clicking a button on my power BI report.
One works perfectly, getting the data from the table rows. However the second one I have made, which uses similar data from a different table, is not being transferred across to the power automate flow and the schema and entity are empty.
I've attempted the following:
- Refreshing the dataset
- Creating a new flow and applying it to the button
- Having the table and button on a separate page
Does anyone know why and how to fix this?
Onboarding flow - working
Onboarding data - working
Offboarding flow - not working
Offboarding data - not working
This was what caused the issue in my case also, opening in the new desinger mode direct in Power Automate rather than via the Power BI Power Automate Visual edit.
I didn't have the specific settings issue with the blank Array field however deleting the On Power BI button trigger and re-adding it via the Power BI visual edit resolved the issue for me whilst doing same from within the flow in Power Apps or Power Automate directly did not.
I'd like to post my experiences with this issue. I believe I found a causal mechanism and now have created a stable flow no matter the changes I make to it. I created the flow from within Power BI Desktop (with the edit selection) and selected the 'Trigger a Power BI button with a custom action', then creating a compose statement selecting one of the input fields. This automatically creates an apply to each loop that iterates through the array passed in to the flow. *I do not edit this apply to each* I create other actions outside of this apply to each. I can create them from within Power BI or Power Automate after that, it doesn't matter. Some time after I start editing this first apply to each, the flow fails for the reasons documented in this thead (power bi does not pass the parameters to power automate). I hope Microsoft fixes this issue. This is very klugey.
This has nothing to do with filters or anything like that. I had a similar issue this week. All of a sudden my Power BI data wasn't send anymore. I compared the run history (csv) and noticed that the trigger step had changed while I didn't make any changes to it.
After doing a little digging I found the root cause:
It looks like this is a bug in the way the "new designer" mode and the old designer mode of a flow interact (save your flow). You probably started the creation of the flow from within Power BI (old mode). If you (accidentally) open the flow in Power Automate in the "new designer" mode it looks like some settings are modified.
If you look at the first step/trigger (in the "new designer" mode) you will notice that the "Array" has gone blank even though you haven't made changes:
Change this value back to:
Save your flow and it will send data again from PowerBi.
Yes, this worked for me. We just need to use the new designer in Power Automate as its trigger condition supports the incoming data stream. Interestingly, Microsoft still provides the old Designer mode by default in Power BI Desktop
Thank you so much! This fixed it for me. Also, you have to watch the Flow save because sometimes it clears it again.
I believe @Sjoshy 's post should be marked as the solution
Here's another twist to the story. In order to see the
you need to be in the new Power Automate editor on the Powerautomate.com website. If you are editing the flow from the legacy editor or from within the Power BI report you will see
which is seemingly the same but will not fix the empty array issue.
Here is what is now working for me whenever the empty array error comes up - go into the new editor, reselect the array, and save the flow. If you make any other edits in the new editor you need to reselect the array as the last thing you do just before saving.
confirmed workaround. Thank you!
same issue here, is it a MSFT bug?
Thank you for this awnser!
What a buggy mess this is. In needed to switch multiple times between old and new design to even see this 'Split on' option and be able to save the adjusted Array. It finally did the job after a couple of hours.
I have the same issue. Funny thing that my flow worked well several days ago. Today, the same flow that worked before started to return "{}" in the output.
The Power Automate button gets its data from the specified columns (in a cross join if needed) BUT impacted by the applied filters. Check the filters.
The easiest way is to use a table visual without totals, then make sure it renders the expected data, and then convert it to a Flow Button visual.
Hi @lbendlin
Thanks for your response. There's no filters set on this page at all and the table has the data I'm expecting.
Visual table A is pulling data from a separate table than visual table B, and the flow running for visual table A is working perfectly so I'm not understanding why the flow running for visual table B isn't.
the table visuals are not important, the filter context of the flow visual is the deciding element.
| 27 | |
| 26 | |
| 22 | |
| 19 | |
| 17 |
| 45 | |
| 42 | |
| 41 | |
| 21 | |
| 18 |
