6 years agoNot applicable
Issue with databrick cluster and Power BI connection using spark cluster
getting this error when connecting Power BI with Azure Databricks through spark build in connector: Details: "ODBC: ERROR [HY000] [Microsoft][DriverSupport] (1170) Unexpected response received from ...
glocea
6 years agoNew Member
Since yesterday, I cannot connect to my spark cluster datasource.
I erased my authentication settings, generate a new token on databricks and log again to my data source.
I keep getting this error
ODBC: ERROR [HY000] [Microsoft][Hardy] (100) The host and port specified for the connection do not seem to belong to a Spark server. Please check your configuration.
Do you have any ideaabout it ? My Power BI Desktop has been updated automaticaly to this version Version : 2.78.5740.721 64-bit
deepu299
Advocate V
6 years agoI had same issue, it seems to be enterprise firewalls. I didn't troubleshoot to find it out, rather used an Azure VM to try and it worked fine. So note that I am just making an assumption here.
