Suyheng's avatar
Suyheng
9 years ago
Generate Unique ID in Power Query (M Code) or Power Power Pivot (DAX Code)
Hi Everyone,
Could anyone help me to write M or Dax Code to generate Unique ID as shown below
Old IDNew IDItemUnique ID
 1ATN13
12ATN23
23ATN33
Many thanks for your help.
Heng
  • Hey,
    just adjust the measure New like so
    New =
    var New =
    IF(HASONEVALUE('Table1'[Customer])
    	,CALCULATE(
            FIRSTNONBLANK('Table1'[New ID], 1)
            ,ALLEXCEPT('Table1',Table1[Customer])
            ,'Table1'[Status] = "Active"
    	,BLANK()
    return
    	,IF(VALUES(Table1[New ID]) = New
    		,New
    		,BLANK()
    and the measure Revenue total like so
    Revenue total =
    var New =
    	,CALCULATE(
    	,BLANK()
    return
    	,IF(VALUES(Table1[New ID]) = [New]
    		,CALCULATE(
    			SUMX(VALUES('Table1'[Customer]),
    				CALCULATE(
    					SUM(Table1[Revenue])
    		,BLANK()
    	,CALCULATE(
    				CALCULATE(
    Then the output will look like this
    Regards
  • Hey,
    can you please describe the rule how the "Unique ID" has to be rerived, and also I do not understand what makes the ID unique if it repeats 3 times.
    Regards
    • Suyheng's avatar
      Suyheng
      Hi TomMartens,
      For example, customer buy house No1 but later they change to House No2 and later on they change to House No3 but the revenue already paid in house No1 and House No 2. Thus I want to sum all the revenue for House No3 which I need to have the same ID in order for me to sum up the revenue
      Input:
      Old IDNew IDCustomerItemStatusRevenueNew
       1CustomerAHouse No1Inactive50003
      12CustomerAHouse No2Inactive100003
      23CustomerAHouse No3Active200003
      Output: M or Dax code to show this result
      23CustomerAHouse No3Active350003
      Many thanks for help
      • TomMartens's avatar
        TomMartens
        Hey,
        so what you are saying is this:
        • the column "New" gets its value from the "latest" (maximum) value of column "New ID"
        • create a measure "overall revenues" and just display the value if the latest "New ID" is selected
        Is my understaning of your requirement correct?
        Regards
